ASR vs 7200 series router
Raghavendra Rai
Hi all,
I have a requirement to creat a testbed where STM1,E3,serial v.35, and g703 E1links should be simulated.
I am confused on which router to go with? 7200,7600 or ASR routers? I would require 6 slots on each router.
Do we have any option to add FXS,FXO ports/cards on any of the above router?
Any of the ISR-G2 platform would suit here?
Your expertise views/inputs will really help. Do let me know if you want more information on the requirement.
Raghavendra
Raghavendra Rai
Is there any FXO & FXS modules which are supported in 7200 VXR or 7600 series router?
Your suggestions will really help.
Tks,
Rghavendra
No, the VXR platform hasn't a kind of FSX/FXO module. Because it is more a high end router, it support voice related communication with the CAS module. Sort of voice trunking.
See for moe info:
http://www.cisco.com/en/US/products/hw/modules/ps2033/prod_brochure09186a008007d45f.html
And the 7600 series router Communication Media Module can contain a combination of T1, E1, and FXS ports. It uses MGCP, H.323, and SIP protocols, and it can provide Survivable Remote Site Telephony (SRST) functionality. The Voice T1/E1 and Services Module, or 6608 blade, can contain T1 or E1 interfaces, and it can perform as an MGCP gateway.
Hope this helps you.
Please click on the correct answer if this answered your question.
Naidu.
