ASR1000 EVC Binding L3-Service to BDI, unable to configure Int VLAN
HUBERT RESCH
Level 3
Level 3
Hi I have configured two EFP into one Bridgedomain with Bridge DomainID 44.
Now I want to have a L3 interface in the BD, as I know from other platforms this is done by configuring
SVI 44 which is associated with BDI 44, so far so good, unfortunately its not possible to configure
the SVI 44, though the parser shows it as an option. Should be also supported on ASR1000 running 3.11,
I could not see another way to enable L3 Service for a BDI
Thx
Hubert
interface GigabitEthernet0/0/0
description **--Ethernet-Backbone A-**
backup interface GigabitEthernet0/0/1
no ip address
negotiation auto
service instance 44 ethernet
  encapsulation dot1q 44 vlan-type 0x9100
  rewrite ingress tag pop 1 symmetric
  bridge-domain 44 split-horizon group 0
description **--Ethernet-Backbone B-**
no ip address
negotiation auto
show bridge-domain 44
Bridge-domain 44 (2 ports in all)
State: UP                    Mac learning: Enabled
Aging-Timer: 300 second(s)
2 ports belonging to split-horizon group 0
    GigabitEthernet0/0/0 service instance 44 (split-horizon)
    GigabitEthernet0/0/1 service instance 44 (split-horizon)
   MAC address    Policy    Tag     Age Pseudoport
Router(config)#int vlan ?
  <1-4095>  Vlan interface number
Router(config)#int vlan 44
% Invalid input detected at '^' marker.
Router(config)#
Leider kann ich so auf die BDI kein Layer 3 binden, hab keine Idee L
interface Vlan44
ip address 172.16.254.1 255.255.255.0
daniel.dib
Level 7
Level 7
According to this document it looks like the syntax is interface bdi instead of interface vlan.
http://www.cisco.com/en/US/docs/routers/asr1000/configuration/guide/chassis/bdi_ps9343_TSD_Products_Configuration_Guide.html#wp1141221
Daniel Dib
CCIE #37149
Please rate helpful posts.
Daniel Dib
CCIE #37149
CCDE #20160011
