03-28-2020 07:44 PM
Having an issue getting Multicast through the Cisco ASR1000.
Simple setup: VM Linux PC 1 & 2, Cisco ASR100 router in the middle (Router on a stick).
Can ping from PC 1&2 to CSR, can ping to/from PC1 & PC2. So generally, looks good.
Have enabled Multicast, and Dense mode on the 2 sub Interfaces, interval query 125 also on interfaces (I have tried with interval Quarry on and off.
Have placed multicast static route on each PC.
When I look at the debug it looks like 1 side is not joining the group.
I suspect its something in the VM setup. Have gone over and over this – now hitting a wall :(
Any ideas appreciated please?
Thank you
Solved! Go to Solution.
03-29-2020 07:11 PM
I found the issues.
2 issues with test tool - Iperf….
1) needed to add a TTL to the Multicast else it was dropping/not crossing the router with a default TTL of 1...
2) Iperf required the Server (listening side) to have -B 225.0.0.x so it knows to listen to/join group.
03-29-2020 07:11 PM
I found the issues.
