ASR1000 QoS issue
xiaodong liao
hello,
     I have a question about qos-group in asr 1000 router, as I read the configuration guide, "The QoS group is a field in the packet data structure internal to the router" as described, So it's only local significant, can I use this way:
1、in the inbound interface, uses MQC to define a traffic and apply to the interface like this:
class-map cs3
match dscp cs3
policy-map qos_marking
  class cs3
   set qos-group 3
interface GigabitEthernet3
    ip address 10.0.0.1
    service-policy input qos_marking
2、in the outbound interface, apply traffic policy based on the marked qos-gropu:
class-map grp3
  match qos-group 3
policy-map qos_set
  class grp3
  bandwidth 4000
interface GigabitEthernet2
description “wan interface”
ip address 20.0.0.1 255.255.255.0
  service-policy output qos_set
Is this kind of configuration take effects?
Francesco Molino
Yes you can use this config to set qos-group as input and define a bandwidth for output.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
Francesco
