ASR1000-SIP10 Insertion Install
Patrick McHenry
Level 4
Level 4
I'm installing a new ASR1000-SIP10 module/blade into a 1006 router. The module will have a 2 DS3 interafce card. I'm looking for a installation doc for the module. I'm sure it is fairly straight forward but, don't want to miss anything.
Also, when I install the module, will there be any configuration for it or will all of my configuration be for the DS3 interface?
Thanks, Pat.
Raju Sekharan
It is straightforward as you mentioned
Here is the doc for OIR for SIP
http://www.cisco.com/en/US/docs/interfaces_modules/shared_port_adapters/install_upgrade/ASR1000/ASRmin.html
Check the sttaus of the PWT and STAT LEDs one you install the SIP
"Showe platform" command will show you once the SIP module has come up
For ASR1000-SIP10, minimum required IOS is Cisco IOS XE Release 2.2
http://www.cisco.com/en/US/docs/interfaces_modules/shared_port_adapters/install_upgrade/ASR1000/ASRmov.html
Raju
Raju Sekharan
Raju
