ASR1000
max-sandoval
%IOSXE_SPA-6-UPDOWN: Interface TenGigabitEthernet0/0/1, link down due to local fault.
I read a post that says:
I sorted out the issue with the below command since they work in WAN mode by default
"hw-module subslot 0/0 enable LAN"
But what happens when you run that command on that subslot, if you already using Interface TE 0/0/0 for your WAN
I just want to use Interface TE 0/0/1 for the LAN
Thank you!
Vinit Jain
The command "hw-module subslot 0/0 enable LAN" is used to move the interface from WAN mode (default) to LAN mode. This is usually required when you are connecting the port to ur LAN environment. You can check the present mode using the command
show controllers wanphy 0/0/1
Was the port ever up or it never came up. If it never came up, you may try changing the mode but i think since the error is pointing to local fault, it may be the problem with fiber or SFP.
Please let me know if that helps.
Vinit
PS: Please rate useful posts.
--Vinit
cisco ASR1001-X that command didn't take
if I do a show controllers this is the result
TenGigabitEthernet0/0/0
3 input vlan errors
1 Number of sub-interface configured
2 input vlan errors
0 Number of sub-interface configured
9329506643243 input vlan errors
0 input vlan errors
GigabitEthernet0/0/2
0 input vlan errors
GigabitEthernet0/0/3
0 input vlan errors
GigabitEthernet0/0/4
0 input vlan errors
GigabitEthernet0/0/5
0 input vlan errors
Sh version
Cisco IOS XE Software, Version 03.13.02.S - Extended Support Release
Cisco IOS Software, ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.4(3)S2, RELEASE SOFTWARE (fc3)
cisco ASR1001-X (1NG) processor (revision 1NG) with 3751700K/6147K bytes of memory.
Processor board ID FXS1835Q2PN
6 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
6688767K bytes of eUSB flash at bootflash:.
some of the logs out of the unit
state to down
*Apr  7 13:45:31.723: %LINK-3-UPDOWN: SIP0/0: Interface TenGigabitEthernet0/0/1, changed state to down
*Apr  7 13:53:22.728: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: SPA bay 0 has no GPIO
*Apr  7 13:53:22.729: %IOSXE-4-PLATFORM: R0/0: kernel: ERROR: Unknow SPA bay number 2
*Apr  9 14:58:42.666: %TRANSCEIVER-6-REMOVED: SIP0/0: Transceiver module removed from TenGigabitEthernet0/0/1
*Apr  9 14:58:55.666: %TRANSCEIVER-6-INSERTED: SIP0/0: transceiver module inserted in TenGigabitEthernet0/0/1
*Apr  9 14:58:57.599: %IOSXE_SPA-6-UPDOWN: Interface TenGigabitEthernet0/0/1, link down due to local fault
