06-03-2014 06:59 PM - edited 03-04-2019 11:05 PM
06-04-2014 12:34 AM
Hi there,
ASR1001 is capable of handling 8000 PPP sessions i think you should not worry about the L2TP tunnels as once the L2TP tunnel is setup between LAC and LNS, all the PPP sessions will be tunneled into L2TP and then handed over to LNS.
For clarification of doubt if you have existing setup running use below command
show vpdn tunnel
it will show you number of tunnels between LAC and LNS if there is only one LAC than you should only be seeing only one tunnel and inside that you will PPP sessions count.
Hitesh Vinzoda
08-19-2015 04:28 AM
hey Guys
wt about ASR 1002 ??
