ASR1001 license activation
vishal-patil
I am using ASR1001 with 03.16.03.S code installed
I activated the advipservices license and did the reboot as well. For some reason, the license is activated but not enabled
ASR1001#show lice
Index 1 Feature: adventerprise
        Period left: 8  weeks 4  days
        Period Used: 0  minute  0  second
        License Type: EvalRightToUse
        License State: Active, Not in Use, EULA accepted
        License Count: Non-Counted
        License Priority: Low
Index 2 Feature: advipservices
        Period left: Life time
        License Type: RightToUse
ASR1001#show lic feature
Feature name             Enforcement  Evaluation  Subscription   Enabled  RightToUse
adventerprise            yes          yes         no             no       yes
advipservices            yes          yes         no             no       yes
Does anyone have any idea why is it doing this? Or I am missing something
Thanks in advance
Mark Malone
Hi you could try ...license right-to-use move (license name)
That should make it permanent might fix it
should say below like my ASR
        License Type: Permanent
        License State: Active, In Use
Tried and got following output
ASR1001#license right-to-use move advipservices
% License is already in RightToUse state
you could contact the license team they should be able to resolve it over the phone for you
https://slexui.cloudapps.cisco.com/SWIFT/LicensingUI/html/contact.html
Ok Thanks
