ASR1001 QOS Problem %QOS-4-TUN_MOV_FAIL
Russ Kwong
Dear member,
I have facing a problem on the ASR with QOS problem, I configured a hqos on phyical interface and hqos on tunnel interface, the number of tunnel about 350.
I check on the logging, the QOS on tunnel was continues fail and install.
%QOS-6-TUN_INSTALL: Installing suspended policy on Tunnel2000.
%QOS-4-TUN_MOV_FAIL: Queueing hierarchy move failed on Tunnel2780, suspending policy.
%QOS-4-TUN_MOV_FAIL: Queueing hierarchy move failed on Tunnel2000, suspending policy.
%QOS-6-TUN_INSTALL: Installing suspended policy on Tunnel3080.
%QOS-4-TUN_MOV_FAIL: Queueing hierarchy move failed on Tunnel3080, suspending policy.
%QOS-6-TUN_INSTALL: Installing suspended policy on Tunnel2380.
%QOS-4-TUN_MOV_FAIL: Queueing hierarchy move failed on Tunnel2380, suspending policy.
%QOS-4-TUN_MOV_FAIL: Queueing hierarchy move failed on Tunnel70, suspending policy.
%QOS-6-TUN_INSTALL: Installing suspended policy on Tunnel2140.
Any member have this experience.
Attach the QoS configuration for reference.
Russ
oscar.ledesma
i don´t know what IOS version you´re using but this could be a bug, #CSCsq24332
http://www.cisco.com/c/en/us/td/docs/ios/12_2sb/release/notes/122SB_cav3.pdf
Seem not related to this bug as ASR only suspended policy without reboot.
Cisco IOS Software, IOS-XE Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.2(4)S, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 23-Jul-12 20:03 by mcpre
IOS XE Version: 03.07.00.S
License Level: adventerprise
License Type: Permanent
Next reload license Level: adventerprise
cisco ASR1001 (1RU) processor with 1156392K/6147K bytes of memory.
Processor board ID SSI170805JC
4 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7741439K bytes of eUSB flash at bootflash:.
