ASR1001x Out-of-Band Access using USR Modem
j10151983
Hi Everyone,
Anyone has deployed USR modem for ASR1001 out-of-band access? I have this setup, wherein OOB access did not work. I connect the modem to Router Aux port, but it is not working, it only shows blank screen from hyperterminal. Also try replacing the modem with same setup, but no luck.I also connect the modem to console port and change the DIP switch setting of the modem, but did not work.
Note: the modem I used works from old Cisco 2951 router.
Dan Lukes
You should not ask in random communities unrelated to the topic - if you wish for answer ...
Please use blue [ EDIT ] button to move it to WAN, Routing and Switching
pyerby1968
Did you ever discover your issue?  I am experiencing the same issue.
