ASR1002 3.16.6S route-map issue
russell.sage
Level 3
Level 3
I have a pair of mpls routers running BGP and redistributing routes into EIGRP.
The redistribution is controlled via a route-map
The route-map has a match statement based on bgp community tags
router eigrp 1
 default-metric 100000 100 255 1 1500
 network 10.3.128.53 0.0.0.0
 network 10.80.95.148 0.0.0.0
 network 10.80.95.156 0.0.0.0
 network 213.12.66.178 0.0.0.0
 redistribute bgp 65139 route-map bgp->eigrp
route-map bgp->eigrp permit 5
 match ip address prefix-list eem-leak-2
 set metric 100
 set tag 4445
route-map bgp->eigrp deny 10
 match community cw-mgt-routes
route-map bgp->eigrp deny 20
 match community local-eigrp-routes
route-map bgp->eigrp permit 30
 match community cw-voice-subnets XXXXXX-voice-subnets
 set metric 100000 50 255 1 1500
 set tag 4445
route-map bgp->eigrp permit 40
 set tag 4445
Named Community standard list cw-voice-subnets
    permit 1:10
    permit 1:20
Named Community expanded list XXXXXX-voice-subnets
    permit _65139:1([0-9][1-9])_
My question is if the prefix being redistributed has a tag of 7100
sh ip bgp 10.232.250.0/24
BGP routing table entry for 10.232.250.0/24, version 8198
Paths: (1 available, best #1, table default)
  Not advertised to any peer
  Refresh Epoch 1
  4445 4445, (received & used)
    10.3.242.245 from 10.3.242.245 (63.130.108.8)
      Origin incomplete, localpref 100, valid, external, best
      Community: 1:10 152:111 65139:7100
      Extended Community: RT:4445:115 RT:4445:702000
      rx pathid: 0, tx pathid: 0x0
Should this not be redistributed with the default metric defined under the EIGRP process or should the permit 40 entry of the route-map have the default metric defined.
You are correct: if it is an eBGP route that is being redistributed, it should get the default metric
If you are redistributing iBGP routes, configure 'bgp redistribute-internal' under the BGP process...
Thanks George
Hello
@russell.sage wrote:
router eigrp 1
 set tag 4445
  Refresh Epoch 1
It will take the default metric values applied in the eigrp process, Unless as you have queried, You set different values with either the redistribute command or in the route-map stanza, both of which which will override the default metric values stated in the eigrp process.
res
Paul
Kind Regards
Paul
