ASR1002-HX ports are not getting up
robinsinghal271
Hi folks,
I have ASR1002-HX and ports are not getting up even after command 'no shut'. Amber light is continuously displaying on the port.
pls help..
8 Replies 8
marce1000
 - Check logs immediately after 'no shut' with show logging , check if you can find additional info's
 M.
Leo Laohoo
Post the complete output to the command "sh license feature".
robinsinghal271
@marce1000  not such additional info i can find. It is showing "SIP0/0: Interface GigabitEthernet0/0/0, changed state to down"
@Leo Laohoo   pls find below sh license feature.
Router#sh license feature
Feature name Enforcement Evaluation Subscription Enabled RightToUse
adventerprise yes yes no yes yes
advipservices yes yes no no yes
ipbase no no no no no
avc yes yes no no yes
broadband no no no no no
broadband_4k no no no no no
cube_250 no no no no no
cube_250_red no no no no no
cube_ent_100 no no no no no
cube_ent_100_red no no no no no
cube_lab no no no no no
cube_video_b2btp no no no no no
cube_video_b2btp_red no no no no no
firewall no no no no no
fpi no no no no no
fwnat_red yes yes no no yes
gtp_addon_aic no no no no no
internal_service yes no no no no
ipsec yes yes no no yes
lawful_intr yes yes no no yes
lisp yes yes no no yes
nat64_stateful_2m no no no no no
otv yes yes no no yes
sgt_fw no no no no no
sw_redundancy yes yes no no yes
throughput yes yes no no yes
vpls yes yes no no yes
FoundationSuiteK9 yes yes no no yes
AdvUCSuiteK9 yes yes no no yes
Thanks..
What ports are you trying to enable, the 10 Gbps ports?
       - Actually what are you connecting on those port(s) , what kind of device , is it fully functional w.r.t networking (?)
 M.
have a look at the document linked below, I think that is what @Leo Laohoo is getting at. Certain ports need certain licenses...
https://www.cisco.com/c/en/us/td/docs/routers/asr1000/install/guide/1001HX_1002HX/b_ASR1001HX-1002HX_HIG/b_ASR1001HX-1002HX_HIG_chapter_0110.html
HI,
Actually there is Bay0 and Bay1. Bay0 has Gig ports and Bay1 Has 10Gig Ports.
 @Georg Pauwen  Yes there is need of port license for ports 4-7  but ports 0–3 can be enabled by default in both Bay respectively.
@Leo Laohoo I am trying to enable ports 0-3 from both Bay but no success.
@marce1000 I am connecting SFP-10G-SR with OM3 cable At Bay1 and GLC-SX-MMD at Bay0. Yes they are fully functional.
Thanks...
The router was only purchased with the most "basic" license.  The only ports that can be enabled are 1 Gbps.
10 Gbps ports will never become enabled until the higher-end license is enabled.
