05-30-2013 09:28 AM - edited 03-04-2019 08:03 PM
Hey all,
Right now I have a ASR1002 running a very old IOS version.
Cisco IOS Software, IOS-XE Software (PPC_LINUX_IOSD-ADVENTERPRISEK9-M), Version 12.2(33)XNE, RELEASE SOFTWARE (fc1)
asr1000rp1-ipbasek9.02.05.00.122-33.XNE.bin – 25-NOV-2009
I am looking to upgrade to a newer version.
I was wondering if there are any tricks when upgradeing this IOS. Is it as easy as loading the IOS onto the ASR and then changing the bootpath or is there an upgrade path I must follow? Also would there any need for a licence between 2.x and 3.x.
Thanks in advance.
05-30-2013 09:52 AM
Steven,
I've installed an ASR 1006 before, and with it, each component, such as route processor, etc can have its own OS, or you can install a AIO package that includes everything. You should be able to go to the data sheet and check it out.
Sent from Cisco Technical Support Android App
05-30-2013 05:55 PM
Don't forget to upgrade the bootstrap.
