ASR1002 status can't up with SFP-GE-T
La Quy Phai
hi all
I have problem with ASR 1002-F and mudule SFP-GE-T.
ASR(SFP-GE-T)-G0/0/0---------------------------------G0/1-SW29600
But when configure ip address for G0/0/0 and see that the protocol and status can't up but the status on SW2960 G0/0 is up
I don't know why, i checked on cisco webside the ASR can support SFP-GE-T module
ashok_boin
Level 5
Level 5
Can you pls post the router config and "sh int" at both ends?
Regards..
-Ashok.
With best regards...
Ashok
Hi Ashok_boin
here config ASR
interface GigabitEthernet0/0/0
ip address 10.1.40.100 255.255.255.0
negotiation auto
GigabitEthernet0/0/0 is down, line protocol is down
  Hardware is 4XGE-BUILT-IN, address is 7081.05e1.5d00 (bia 7081.05e1.5d00)
  Internet address is 10.1.40.100/24
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive not supported
  Full Duplex, 100Mbps, link type is force-up, media type is T
  output flow-control is on, input flow-control is on
  Last input never, output never, output hang never
  Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 8 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet0/0/1 is administratively down, line protocol is down
  Hardware is 4XGE-BUILT-IN, address is 7081.05e1.5d01 (bia 7081.05e1.5d01)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Full Duplex, 1000Mbps, link type is auto, media type is T
  output flow-control is unsupported, input flow-control is unsupported
     0 output errors, 0 collisions, 2 interface resets
Swtich 2960 Default config
It looks like Auto negotitation is NOT supported on SFP-GE-T as per the following link. Can you please try with turning off negotitation and manually configure speed/duplex?
http://www.cisco.com/en/US/prod/collateral/routers/ps9343/qa_c67-496324.html
Regards...
-Ashok.
Ashok
here config ASR
speed 100
no negotiation auto
no change status when i try
