ASR1006 show log: ipnat_update_static_refcnt????
makinosora
Hi everyone,
I have a ASR 1006.
ASR-R#show version
Cisco IOS Software, IOS-XE Software (PPC_LINUX_IOSD-ADVENTERPRISEK9-M), Version 15.3(2)S2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Wed 14-Aug-13 11:16 by mcpre
IOS XE Version: 03.09.02.S
Cisco IOS-XE software, Copyright (c) 2005-2013 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
ASR-R uptime is 19 weeks, 2 days, 4 hours, 58 minutes
Uptime for this control processor is 19 weeks, 2 days, 5 hours, 1 minute
System returned to ROM by reload
System restarted at 08:55:45 CST Mon Sep 23 2013
System image file is "bootflash:asr1000rp1-adventerprisek9.03.09.02.S.153-2.S2.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco ASR1006 (RP1) processor with 1672999K/6147K bytes of memory.
Processor board ID FXS1711Q649
4 FastEthernet interfaces
5 Gigabit Ethernet interfaces
1 Ten Gigabit Ethernet interface
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
937983K bytes of eUSB flash at bootflash:.
39004543K bytes of SATA hard disk at harddisk:.
Beginning last month, I got a lot of message about NAT at log.
Here is a part of message:
ASR-R#sh log
Feb  5 13:54:37.685: ipnat_api_del_ipalias - failed to find idb for alias_addr 61.56.15.215 in table_id 0
Feb  5 13:55:17.675: ipnat_update_static_refcnt - nat entry 0x41C52C58  mapping_id 167 updated - nat->refcount 0 nat->usecount 0
Feb  5 13:55:32.030: ipnat_api_add_ipalias - failed to find idb for alias_addr 61.56.15.215 in table_id 0
Feb  5 13:55:48.387: ipnat_update_static_refcnt - nat entry 0x41C57458  mapping_id 238 updated - nat->refcount 0 nat->usecount 0
Feb  5 13:56:00.324: ipnat_update_static_refcnt - nat entry 0x41C55D58  mapping_id 216 updated - nat->refcount 0 nat->usecount 0
Feb  5 13:56:00.691: ipnat_update_static_refcnt - nat entry 0x41C55D58  mapping_id 216 updated - nat->refcount 1 nat->usecount 1
Feb  5 13:56:04.968: ipnat_update_static_refcnt - nat entry 0x41C52558  mapping_id 160 updated - nat->refcount 1 nat->usecount 1
Feb  5 13:57:04.078: ipnat_update_static_refcnt - nat entry 0x41C55D58  mapping_id 216 updated - nat->refcount 0 nat->usecount 0
Feb  5 13:57:04.895: ipnat_update_static_refcnt - nat entry 0x41C55D58  mapping_id 216 updated - nat->refcount 1 nat->usecount 1
Feb  5 13:57:06.009: ipnat_update_static_refcnt - nat entry 0x41C52558  mapping_id 160 updated - nat->refcount 0 nat->usecount 0
I can't find any information about this message. What's that mean??
0 Replies 0
