ASR9000 BNG Links
lorenzo limardo
Good morning,
I would need to know if this configuration may works, or if you may suggest  something better.
our idea is to setup the following network topology. As you can see, both ASR's are redundant and can stand a failure on our providers AS174 (Cogent) or AS8928 (Interoute) but not at same time, we can even shut down one of the ASR without losing internet connectivity, so our first option is to connect our clients on 7600, because otherwise we can't connect them to both ASR's.
Configuring BNG on the ASR's to connect there the PPP clients is our plan B ;)
Would config be good?
For reason costs, we would like to use TRIDENT REDUNDANT CARDS LOW QUE 10 GBE ( A9K-8t-l)
Thyphoon, or tomahawk cards, are really too much expensive.
Main question about the ASR9006 is the 1 million routes limit of the trident card. This way we are limited to maximum-paths=1, what happens during BGP convergence? Do you lost connectivity? This is our main concern.
Thanks a lot for the help.
0 Replies 0
