ASR920-L2
fachahbar
How Should I configure layer 2 vlan in an asr920 as "best practice.
Any suggestions?
lespejel
Level 3
Level 3
depends, check configuration guides, first question, configure VLANs where?
https://www.cisco.com/c/en/us/td/docs/routers/asr903/software/guide/chassis/xe-3s/b_Config_Guide_fullbook.html
CCIE 52804
hi,
Thank you for your reply, but unfortunately there is not much info about configuring  layer 2 interface i ASR920
as far as I can remember, ASR900 uses BDI instead SVI, I hope it helps.
CCIE 52804
Yes that is correct. The ASR920 family uses BDIs. You can assign any sub-interface from any interface to any BDI, which means that you can effectively bridge any VLAN to any other VLAN by using the same "bridge domain" group. Try not to confuse yourself!
Hope this helps
Dave
