assymetric routing
alsayed
HI
What does it mean Technicaly "assymetric routing "
10xs
vladrac-ccna
Level 5
Level 5
quoting:
Asymmetric routing in general is a normal, but unwanted situation in an IP network. Asymmetric routing is a situation where for one reason or another packets flowing in i.e. TCP connections flow through different routes to different directions. As a rough example: Host A and B located in different continents are communicating through a TCP connection. Segments sent from host A to host B reach the destination through Sprint link but segments sent from B to A reach the destination through MCI link.
Asymmetric routing as described above is not a problem for current TCP/IP implementations, since TCP connection does not care which route a certain IP packet takes as long as it reaches its destination in a reasonable time.
Asymmetric routing can occur in a smaller scale also. It could happen in a situation where an organization uses two different routes, like a VPN and a leased line, for instance, to their branch office. ...situation where segments on a single connection come in to the network through one node and go out through another node.
Vlad
devang_etcom
Level 7
Level 7
hi ali,
in assymetric routing packet follow the two different path for incoming and outgoing...
it means if hostA is connected with the hostB with two different link then packet from hostA will travel to one path to reach destination(to hostB) and packet from B will travel to other path to reach destination (hostA), this is just one example to understand but in ISP you can have different scenario.
normally its not good to have assymetric routing in your network as it will create more complexity during the troubleshooting networks...
regards
Devang
10xs for ur time..
