ATM Configuration
cisco
Kindly let me know , when i configure CBR or vbr-nrt , in which case do i have to give bandwith in Kbps and in which case i have to give bandwith in Cells.
regards
Neo
paolo bevilacqua
On the router, bw for VC is always in kbps. Note that from the router perspective, cbr is the same as vbr with scr=pcr.
See:
http://www.cisco.com/en/US/tech/tk39/tk51/technologies_tech_note09186a00800c69bb.shtml
(that is a document that I had originally authored)
Hope this helps, please rate all useful posts!
Hi ,
Are you sure , because one of my collegue is confirming that he has configured BW in Cells for CBR and for nrt-VBR BW is in Kbps
regards
No Sir if we are discussing routers all the BW are in kbps. This indicated by the CLI itself.
What platform are you using ?
