ATM goes down and Standby processor fault
enriquebs
HI all,
We have a 7604 router with two route processors and an ATM interface, here is a sh ver output:
PE01#sh ver
Cisco IOS Software, 7300 Software (C7300-K91P-M), Version 12.2(27)SBC2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 25-Jan-06 18:21 by hqluong
ROM: System Bootstrap, Version 12.1(12r)EX1, RELEASE SOFTWARE (fc1)
PE01 uptime is 3 weeks, 3 days, 15 hours, 29 minutes
Uptime for this control processor is 3 weeks, 3 days, 15 hours, 30 minutes
System restarted at 18:35:50 METDST Thu May 18 2006
System image file is "disk0:c7300-k91p-mz.122-27.SBC2.bin"
cisco 7300 (NSE100) processor (revision E) with 491520K/32768K bytes of memory.
Processor board ID SMQ0938N27F
R7000 CPU at 350Mhz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
4 slot midplane, Version 67.49
Last reset from power-on
PXF processor tmc0 'system:pxf/ucode1' is running ( v4.1 ).
PXF processor tmc1 'system:pxf/ucode1' is running ( v4.1 ).
1 FastEthernet interface
4 Gigabit Ethernet interfaces
1 ATM interface
509K bytes of non-volatile configuration memory.
125440K bytes of ATA compact flash in bootdisk (Sector size 512 bytes).
125184K bytes of ATA compact flash in disk0 (Sector size 512 bytes).
Standby route processor in slot 2 is up with 524288K/32768K bytes of memory.
Standby image version:
The thing is from time to time the ATM interface goes down and after this event there is a change to the standby route processor, here are some lines from the log output:
Jun 11 03:56:37: %WS_ALARM-6-INFO: ASSERT CRITICAL ATM4/0 Loss of Cell Delineation
Jun 11 03:56:37: %WS_ALARM-6-INFO: ASSERT CRITICAL ATM4/0 Physical Port Link Down
Jun 11 03:56:37: %WS_ALARM-6-INFO: CLEAR CRITICAL ATM4/0 Loss of Cell Delineation
Jun 11 03:56:37: %WS_ALARM-6-INFO: ASSERT CRITICAL ATM4/0 Path Far End Receiver Data Failure
Jun 11 03:56:37: %WS_ALARM-6-INFO: CLEAR CRITICAL ATM4/0 Path Far End Receiver Data Failure
Jun 11 03:56:37: %WS_ALARM-6-INFO: ASSERT CRITICAL ATM4/0 Path Alarm Indication Signal
Jun 11 03:56:39: %LINK-3-UPDOWN: Interface ATM4/0, changed state to down
Jun 11 03:56:53: %REDUNDANCY-3-STANDBY_LOST: Standby processor fault (PEER_NOT_PRESENT)
Jun 11 03:56:53: %WS_ALARM-6-INFO: ASSERT MAJOR NSE100 Secondary removed
Jun 11 03:56:53: %REDUNDANCY-3-STANDBY_LOST: Standby processor fault (PEER_DOWN)
Jun 11 03:57:56: %REDUNDANCY-5-PEER_MONITOR_EVENT: Active detected a standby insertion (raw-event=PEER_FOUND(4))
Jun 11 03:57:56: %WS_ALARM-6-INFO: CLEAR MAJOR NSE100 Secondary removed
Jun 11 03:58:02: %HA-6-MODE: Operating RP redundancy mode is SSO
Jun 11 03:58:09: %BGP-5-ADJCHANGE: neighbor 10.9.154.1 vpn vrf VPN_VoIP Up
.Jun 11 03:58:17: %STANDBY-3-MSG:
.Jun 11 03:58:51: %HA-6-STANDBY_READY: Standby RP in slot 2 is operational in SSO mode
Have somebody any idea about what is happening here? I don?t understand the relation between these two events...
Thanks a lot in advance.
Kike
0 Replies 0
