ATM over E3 Unframed WAN
h00nix101
We are installing a new E3 unframed circuit 34Mb, and trying to use existing PA-A3-E3 ATM cards.
Since there is no longer an ATM switch, is there anything we need to do to account for this?
Below is the configuration, which has been used but is unsucessful.
Both routers are 7204VXR's running 12.2(28).
Router#1
interface ATM1/0
no ip address
ip route-cache flow
no atm ilmi-keepalive
e3-scramble
interface ATM1/0.99 point-to-point
bandwidth 34000
ip address 10.155.211.129 255.255.255.252
pvc 0/99
encapsulation aal5snap
Router #2
interface ATM1/0
no ip address
ip route-cache flow
e3-scramble
bandwidth 34000
ip address 10.155.211.130 255.255.255.252
pvc 0/99
mheusinger
Level 10
Level 10
what is the error codition? Output of "show interface"?
Martin
ATM 1/0 is down no traffic at all, both sides.
There is a fault light indicator light on both sides.
on the respective ATM cards. CD is light green.
from show controllers: Facility ALarm: AIS.
The circuit has been checked by Telco and its apparently fine.
Is each router expecting a repsone from an ATM switch, thus raising the AIS?
Heres the output from debug
012146: Apr 6 20:07:17.559 DST: atmdx_cstate(ATM1/0): state=6 atm_lineup=0
012147: Apr 6 20:07:18.567 DST: (ATM1/0) Received Heartbeat message
012148: Apr 6 20:07:19.851 DST: (ATM1/0) Received Heartbeat message
012149: Apr 6 20:07:21.139 DST: (ATM1/0) Received Heartbeat message
012150: Apr 6 20:07:22.427 DST: (ATM1/0) Received Heartbeat message
012151: Apr 6 20:07:23.199 DST: -Traceback= 6038ADC0 605831E4 60582AA8 60582780 6053C510 6054A66C 605AEBE8 605AEBD4
012152: Apr 6 20:07:23.199 DST: atmdx_reset(ATM1/0): state=0 status=0x44218000 oir_flags=0
012153: Apr 6 20:07:23.199 DST: atm: config_status 0, flags 0x48100
012154: Apr 6 20:07:23.199 DST: atmdx config(ATM1/0)
012155: Apr 6 20:07:23.199 DST: atmdx_pas_config(ATM1/0): max_vpi_bits 8, max_vci_bits 16, max_cell_rate 80000, max_vc 4096
012156: Apr 6 20:07:23.199 DST: clock_source 1, loop_status 0, scr 1, txlbo 0, framing 3
012157: Apr 6 20:07:23.219 DST: atmdx_enable(ATM1/0): state 0 atm config_status 0, flags 48100
012158: Apr 6 20:07:23.219 DST: atmdx_enable(ATM1/0): restarting vc
012159: Apr 6 20:07:23.219 DST: atmdx_pas_restart(ATM1/0): state 0
012160: Apr 6 20:07:23.315 DST: pmc_pm7345_isr: received framer int 0x48, old alarm 0x0000
012161: Apr 6 20:07:23.315 DST: mgmt interrupt status 0x00000240
012162: Apr 6 20:07:23.315 DST: e3 frmr interrupt status 0x11
012163: Apr 6 20:07:23.315 DST: e3 alarm maint_int 0xED status 0xBC alarm 0x0020
012164: Apr 6 20:07:23.315 DST: atmdx_alarm_handler(ATM1/0): alarm 0x0020, state 0
012165: Apr 6 20:07:23.315 DST: ATM1/0: LED turned 1
012166: Apr 6 20:07:23.315 DST: ATM(ATM1/0): interface not up
012167: Apr 6 20:07:23.315 DST: ATMSIG: sscop open successful
012168: Apr 6 20:07:23.711 DST: (ATM1/0) Received Heartbeat message
012169: Apr 6 20:07:23.995 DST: pmon_change 0x08, cppm_change 0x50
012171: Apr 6 20:07:24.999 DST: (ATM1/0) Received Heartbeat message
012172: Apr 6 20:07:25.199 DST: %LINK-3-UPDOWN: Interface ATM1/0, changed state to down
How did you configure clocking?
AIS is usually present in a framed line. It tells, that this interface is OK, but the other end (connected device) is having a problem. The reason can be f.e. LOS, LOF and the like.
So you would need to check the other end. Once you figure that the AIS is from the provider equipment (if both routers are reporting AIS) he needs to check this again.
You might also want to read the document "Troubleshooting Line Problems and Errors on DS-3 and E3 ATM Interfaces" at
http://www.cisco.com/en/US/tech/tk39/tk48/technologies_tech_note09186a0080111093.shtml
Hope this helps! PLease rate all posts.
Regards, Martin
WAN circuit is unframed.
Used atm clocking internal under both ATM 1/0 cards
