ATM sub-interface routing
jefft
Visitor
Currently My  DSL Circuits are configured on Bridged ATM sub-interfaces with IP at the BVI interface. The Hardware I am using is a 7206VXR. I am looking to see if the following is possible:
Have an ATM subinterface for the DSL connectivity and do the L3 on a vlan. For instance, have the ATM2/0.3050 use Interface G0/1.50 instead of a BVI interface.
Anyone know if this is possible and How?
Jeff
paolo bevilacqua
Yes. Under ATM subinf configure, "atm ip route-bridged", IP address, and eliminate bridge.
Hi Paolo,
Thanks for the reply. I have an additional question.
The 7206VXR G0/1 interface which is connected to a 3750 trunk port is configured like below:
interface GigabitEthernet0/1
no ip address
ip flow ingress
load-interval 30
duplex auto
speed auto
media-type rj45
no negotiation auto
no keepalive
interface GigabitEthernet0/1.3
encapsulation dot1Q 3
ip address x.x.x.x y.y.y.y
interface GigabitEthernet0/1.4
encapsulation dot1Q 4
no ip address
Can I make the ATM subint part of vlan 4? I would like to configure the ip address for this side of the connection on a layer 3 device connected to a 3750 port that is part of vlan 4. After "atm ip route-bridged", can I configure "encapsulation dot1Q 4"?
That would be a different thing - instead of terminating L3 on the 7200, you want to bridge packets to a 3750.
Note, I recommend that you always terminate ADSL connections on a true router, not a layer3 switch..
Anyway to do that, keep the bridge-group, but eliminate the BVI.
Thanks for the nice rating, and good luck!
Hi Paolo,
I did what you suggested:
1. Keep the bridge-group (bridge-group 4)
2. Eliminate the BVI
3. Made the GigabitEthernet0/1.4 subinterface part of the bridge-group:
bridge-group 4
no ip address
When I created interface Vlan4 on the 3750 with ip address in the same subnet as the WAN interface of the remote DSL router, I could ping and telnet to the devices on both ends.
Thank you very much.
