autoboot: boot failed, restarting...System integrity status: 0x610
khan.adil040
Initializing Hardware ...
Checking for PCIe device presence...done
Rom image verified correctly
System Bootstrap, Version 16.7(3r), RELEASE SOFTWARE
Copyright (c) 1994-2017 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: LocalSoft
ISR4221/K9 platform with 4194304 Kbytes of main memory
Device not found flash:
Resetting .......
Resetting .......
please help me out about this issue.
Leo Laohoo
I know what this is:
Force the router into ROMMON.
johnlloyd_13
Level 9
Level 9
hi,
try to break the bootup and go into ROMMON mode.
manually boot using the current IOS-XE stored in bootflash or use an external USB stick.
once it normally boots up again, check the boot variable. ensure it uses 'bootflash':
boot system flash bootflash:<IOS.bin>
