AutoCAD Drawing Catalyst 2955
mgerbasio
Does Cisco have AutoCAD blocks available for its equipment? Specifically looking for an AutoCAD drawing of the Catalyst 2955. Thanks.
Regards-Michael G.
Reza Sharifi
Hi Michael,
As far as I know Cisco only has icons for Visio and Power Point.
http://www.cisco.com/web/about/ac50/ac47/2.html
Reza
Thanks Reza. I checked the link but the symbols really aren't detailed enough. Hopefully someone from Cisco can point me in the right direction.
Mike,
You may also post your query in the "Idea Center" section under "Technical Documentation" sub-forum. You probably get a better response, because Cisco doc people read and response there mostly.
Reza
Thanks. Just posted.
