B.T.U information for Cat6509 access switch
chris.lau
Hello there,
Can I know whether to get information about the B.T.U per hour for Cat6509 with dual 6000W PS?
Thank you
Ganesh Hariharan
Hello there,
Thank you
Check out the below link for Chassis and Module Power and Heat Values :-
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/hardware/Chassis_Installation/Cat6500/0dpwrht.html
or
Refer Link below for CISCO Power Calculator Tool:
http://tools.cisco.com/cpc/launch.jsp
The Cisco® Power Calculator enables you to calculate the power supply requirements cisco devices.
Hope to Help !!
Ganesh.H
