%BACKPLANE_BUS_ASIC-4-DEV_RESET and %EARL_L2_ASIC-SP
iamjedski
SLOT 4/0: *Apr 1 22:28:12.843 UTC: %BACKPLANE_BUS_ASIC-4-DEV_RESET: Backplane Bus Asic reset, interrupt [0x0150]=0x0900
SLOT 4/0: *Apr 1 22:28:12.843 UTC: %BACKPLANE_BUS_ASIC-4-DEV_RESET: Backplane Bus Asic reset, interrupt [0x0150]=0x0800
SLOT 7/0: *Apr 1 22:28:12.843 UTC: %BACKPLANE_BUS_ASIC-4-DEV_RESET: Backplane Bus Asic reset, interrupt [0x0150]=0x0B00
SLOT 7/0: *Apr 1 22:28:12.843 UTC: %BACKPLANE_BUS_ASIC-4-DEV_RESET: Backplane Bus Asic reset, interrupt [0x0150]=0x0800
SLOT 3/0: *Apr 1 22:28:12.839 UTC: %BACKPLANE_BUS_ASIC-4-DEV_RESET: Backplane Bus Asic reset, interrupt [0x0150]=0x0900
SLOT 3/0: *Apr 1 22:28:12.843 UTC: %BACKPLANE_BUS_ASIC-4-DEV_RESET: Backplane Bus Asic reset, interrupt [0x0150]=0x0800
*Apr 2 00:30:22.078 UTC: %EARL_L2_ASIC-SP-STDBY-4-L2L3_SEQ_ERR: EARL L2 ASIC #0: L2L3 Mismatch seq #0x609
*Apr 2 00:30:22.077 UTC: %EARL_L2_ASIC-SP-4-L2L3_SEQ_ERR: EARL L2 ASIC #0: L2L3 Mismatch seq #0x609
*Apr 2 00:30:22.077 UTC: %EARL_L2_ASIC-SP-3-INTR_WARN: EARL L2 ASIC 0: Non-fatal interrupt l2l3_seq_mismatch
*Apr 2 00:30:22.078 UTC: %EARL_L2_ASIC-SP-STDBY-3-INTR_WARN: EARL L2 ASIC 0: Non-fatal interrupt l2l3_seq_mismatch
Should we reset the whole chassis or the hardware module?
Leo Laohoo
Just the blade/module.
Supervisor module?
The line card.
