Backup issue over WAN Link
abbas.ali
We have a customer how has a 10Gb Sat link between the HQ and the DR site.  They are having latency issues when copying backup transactional data between the HQ and DR site.  On a 10gb WAN link, the 4/5 gb of backup takes more than an hour.  The WAN is connected via Cisco Router and the routers are not doing any kind of traffic filtering or policing.
I noticed that the  “Jumbo Frames” are enabled (on the network equipment?) in HQ, but not at the DR.
Could this possibly allow the Customer to have good experiences locally in HQ – but then compromised when data is transferred externally to the non-Jumbo Frame site?
Please advise!
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
It's a little unclear what the "latency issues" are.  Are you saying there's latency issues when doing the backup or latency issues because of the backup?  If the former, ever read or hear the late Grace Hopper's explanation of using satellite connection?  The latter is often resolved with QoS.
Also if the former, backup impacted by latency, google BDP or bandwidth delay product.
Non jumbo frames support end-to-end shouldn't be an issue assuming there's L3 end-to-end as normally PMTUD would discover the maximum MTU end-to-end although having such support end-to-end would likely increase you backup transfer performance.
