backup MPLS over internet
q1gznn111
I have main HQ and 7 branches and these branches connected to HQ over MPLS . I want to apply backup soulution over internet . what is the best way to do that and i have one router in each branch face to the internet and MPLS .
6 Replies 6
Julio E. Moisa
I think you could implement: VPN Site to Site, DMVPN, or IPSEC-GRE tunnels. But you should see if your devices support that and If you have Public IP addresses.
Also check this link:
https://supportforums.cisco.com/t5/wan-routing-and-switching/best-way-to-backup-mpls-over-internet/td-p/2279230
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Thank you Julio I wants you to know that I have only one router which I used it to forward traffic over MPLS and the same router I want create a backup link from it over the internet. For more info please find the attached snap.
The best solution can be IPSEC over GRE because can you can involve routing protocols on that to manipulate the traffic and it can be run on your devices with the proper IOS.
Thanks I will apply this solution and back to you
Yes, I will be here for any required assistance.
Have a great day.
