Backup primary link with ADSL
mljevakovic
Level 3
Level 3
How can I backup primary link to my ISP to another over ADSL. I have Ethernet connection by wireless to one ISP and now I want implement backup solution to another ISP over ADSL.
Pls asap.
vijayasankar
Level 4
Level 4
This topic has been discussed several times in this post.
For this, you need to use a feature called reliable static routes using object tracking.
Using this you can configure the router to send periodic pings to the other end ip of the service provider. As long as this ping works fine, the defautl route that you have configured in the router will be taking effect. Once the router sees that no long the ping to the specified host is working, the default route in your router will be removed and the next best route available in your routing table ( floating static route pointing to the ISDN) will take effect.
Have a look at the following URL
http://www.cisco.com/en/US/products/sw/iosswrel/ps5413/products_feature_guide09186a00801d862d.html#wp1071672
Have a look at these posts too.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=WAN%2C%20Routing%20and%20Switching&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1ddc1e78
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=WAN%2C%20Routing%20and%20Switching&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1ddc1dc1
Hope this helps.
-VJ
