Backup VPN over Internet + Internet Link (Utilization Scenario)
guruprasadr
Level 7
Level 7
Reg:Backup VPN over Internet+InternetLink
Total Link Bandwidth: 10000Kbps
Single Link = Internet + VPN Link
Mux---->Wired Conn..---->Internet Router
Europe - India --->Logical VPN Tunnel
My Internet-int B/W given as:10000
My VPN Tunnel B/W given as:10000
Consider my Internet B/W has peak Utilization of 9000Kbps & if i want to move my Data Traffic via Bkp VPN Link means whether i will be able to use left out 1000Kbps in the Link.
Internet Link is not a Problem ! !
Since, only Internet Router has the Conn..to the ISP MUX & Bkp VPN is a Logical Configuration of Tunnel. All my Data Traffic via Bkp VPN Link will go the Internet Router & reach MUX, finally to Europe side (or) how ? ?
Kindly Help on this Issue.Thanks in Advance.
Thanks & Regards,
Guru Prasad R
spremkumar
Level 9
Level 9
Hi Guru
I feel you need to put more clarity on the kinda topology you have in place at present and also a pictorial representation of the setup you have in place ..
regds
HI Premkumar,
I was investigation more on the set-up.
1. Internet Router
a. Fast Eth 0/1 - 10Mbps to MUX
b. Fast Eth 0/0 - Link to DMZ Switch
2. Backup VPN Router
a. Fast Eth 0/1 - Link to WAN Switch
b. Logical Tunnel - Bandwidth of 10Mbps
3. Juniper Networks Netscreen - Firewall
a. Interface Connected - DMZ Switch
My Scenario:
If my Data is going via Backup Link means i would like to know the Route of Traffic.
WAN Switch-->Backup VPN Router Tunnel-->
-->Juniper Firewall-->DMZ Switch--->Internet
Router-->to MUX Device
Thanks in Advance ! ! Guru Prasad R
