Backup Wan Link configuration
Hello All Experts.
We have recently shifted from 2Mbps to 10Mbps. 10Mbps is terminated directly on router on fa0/1 and 2Mbps is a serial link.
I was thinking of utilizing the 2Mbps as a backup link instead of terminating.
Is it possible to configure serial 2Mbps as backup link.
Can some one help me with the configuration part
my current config is
interface FastEthernet0/0
description "Connected to ****** Lan"
ip address *.*.*.* 255.255.255.248
ip route-cache flow
duplex auto
speed auto
interface FastEthernet0/1
description "Connected to ****** Link"
bandwidth 10000
ip address 10.10.10.1 255.255.255.252
ip route-cache flow
shutdown
duplex auto
speed auto
traffic-shape group 100 4000000 100000 100000 1000
interface Serial0/0/0
ip route-cache flow
no fair-queue
ip classless
ip route 0.0.0.0 0.0.0.0 X.X.X.53
ip route x.x.x.x 255.255.255.0 10.10.10.2
ip flow-export source FastEthernet0/1
ip flow-export version 5
ip flow-export destination X.X.X.X 9996
ip http server
ip http port 1311
ip http authentication local
ip http max-connections 1
snmp-server community public RO
snmp-server ifindex persist
control-plane
banner motd ^CWelcome to ****** Router^C
line con 0
line aux 0
line vty 0 4
login local
transport input telnet
end
sean_evershed
Level 7
Level 7
I suggest you configure Reliable Static Routing Backup Using Object Tracking. See below a configuration guide:
http://www.cisco.com/en/US/docs/ios/12_3/12_3x/12_3xe/feature/guide/dbackupx.html#wp1071672
Cheers
Sean
Sean,
Thanks for the update, I will try the same and trouble you again if I get stuck
Deepak
Sean,
I tried to configure as per the example "Configuring Reliable Static Routing Backup Using Object Tracking: DHCP Example
The following example configures the Reliable Static Routing Backup Using Object Tracking feature using DHCP. The primary interface is an Ethernet interface, and the backup interface is a serial interface. This example applies to Cisco IOS Release 12.3(14)T and later releases."
However I am not sure how will I implement it in my kind of senario as there is no DHCP configured or used in the router.
Can you please guide me on this.
Deepak Suryavanshi
Please make following chnages
bandwidth 10000
ip route-cache flow
no shutdown  <<< Turn on this circuit
duplex auto
speed auto
ip route-cache flow
no fair-queue
i
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1
ip route 0.0.0.0 0.0.0.0 Serial0/0/0 100 <<< You can increase AD value to 100.
This should work . Otherwise you can work via SLA tracking feature.
router#config terminal
router(config)#ip sla 1
router(config-ip-sla)#icmp-echo source-int router(config-ip-sla-echo)#exit
router(config)#ip sla 2
router(config)#ip sla schedule 1 life forever start-time now
router(config)#ip sla schedule 2 life forever start-time now
router(config)#track 1 rtr 1 reachability
router(config)#track 2 rtr 2 reachability
router(config-track)#exit
router(config)#ip route 0.0.0.0 0.0.0.0 track 1
router(config)#ip route 0.0.0.0 0.0.0.0 track 2
Please let me know if it helps
