Backup
imane
I have 2 connection WAN ( Wimax and 3G), i want to use the link 3G as a Backup of the main link Wimax, has knowledge that I cannot use the Dynamic routing?
tj.mitchell
Level 4
Level 4
don't understand "has knowledge that I cannot use the dynamic routing" does that mean you can't use dynamic routing protocols?
Are you routing over the links?
How is connectivity established currently?
Yes i can't use dynamic routing protocols, i just use the static routes.
You can then use IP SLA commands to take care of the issue.
http://www.cisco.com/en/US/docs/ios/12_4/ip_sla/configuration/guide/hsla_c.html
i tray to use IP SLA
