Bandwidth check for wan router
mohamed fayz
Hai all,
I have one wan router, which is connecting between two sites using service provide MPLS link and we created tunnel between these two sites for interconnection. Now, i have a simple doubt for checking the bandwidth of remote site. is there any Option, i mean the bandwidth which is provided by service provide to Wan router. Please let me know the different option if any???
ohassairi
Level 5
Level 5
you can generate traffic between the 2 sites (file transfer for example) then use show interface command to check for speed by looking to : 5 min input/output.
but you need to wait for 5 min to get accurate result. you can also change this value: under interface tunnel you type: load-interval 30 (to get the value of 30s)
if you are familiar with SNMP you can also use some free software like PRTG to measure interface speed.
