bandwidth command is not supported in output direction for this interface
manik.palekar
m getting error"bandwidth command is not supported in output direction for this interface " during configuration service-policy output command on interface.Please suggect how to configure...
Thanks in advance
gunner07971
Are you using something like a Cat 3750? If so you need to use the following command in order to use bandwidth throttling on an interface
srr-queue <10 - 90>
Where <10 - 90> is the percentage that you want to throttle the bandwidth by.
m configuring it on cisco 12000 series router Version 12.2(18)SXF12a,...
