Bandwidth Command
Amin Shaikh
Level 6
Level 6
Applying
bandwidth
command on interface, will this restrict traffic according to the bandwidth defined.
int fa 0/0
bandwidth 2000
will send and receive be restricted to 2MB as above config.
yagnesh_tel
Level 6
Level 6
No, it won't restrict your interface speed to 2MB. But configured
bandwidth
under interface will be used by routing protocols to calculate their metrics. TCP will also adjust its initial retransmission parameters based on the
bandwidth
configured on the interface. Also if QoS is used,it will use this as reference bandwidth.
So it is still important to configure interface with right
bandwidth
statement.
7 Replies 7
yagnesh_tel
Level 6
Level 6
bandwidth
bandwidth
bandwidth
statement.
"TCP will also adjust its initial retransmission parameters based on the bandwidth configured on the interface."
I was unaware of this.
This is for TCP traffic sourced from the network device?
Can you provide any reference?
Joseph,
seems here Yognesh wants to say - this
bandwidth
command adjest the TCP window size in random manner.
Yognesh - is it right ????
good explanation of
bandwidth
command !!!!!!
Lucien Avramov
Level 11
Level 11
You can limit BW with Qos, for example for VoIP traffic :
int f0/0
service-policy output ect_policy
policy-map ect_policy
class ect_class_voice
bandwidth 64
class-map match-all ect_class_voice
match protocol h323
Hi Lucien,
From you message "You can limit BW with Qos".
Maybe you want to say something else, but
bandwidth
in the policy-map will not limit the BW. It will
guarantee
BW during congestion.
jerry
I want to give an example on how you can have 2 megs of bw guaranteed for specific traffic.
There is no point of making a pipe smaller than what it is, so QoS is a way to segment it into pieces as you know and guarantee traffic.
"There is no point of making a pipe smaller than what it is . . ."
To clarify for others, that although this is normally true, there are exceptions.
For instance, you might have a physical interface much faster than the end-to-end path supports. In such cases, you might want to slow a faster interface to match available
bandwidth
further along the path. (E.g. Ethernet hand-off to some WAN technology.)
Another instance, for some policy (or other special) reason, you might want to provide all or some traffic less
bandwidth
than what's actually available. (E.g. using VPN, you don't want VPN traffic sent to a remote site to fully utilize all remote's Internet
bandwidth
leaving some
bandwidth
for remote's native Internet traffic.)
