Bandwidth consumption for specific IP
Ibrahim Jamil
Level 6
Level 6
Hi Guys
how can i verify a particular ip address how much bandwidth he consumes(download for the internet) in order to police this traffic
thanks
jamil
cadet alain
you can do this with different features:
-ip accounting
-NBAR protocol-discovery
-Netflow
-MQC
Regards.
Alain.
Hi Guys
where to configure this? at the Internet router ? or in the core switches where the users are connected?
which is the best of the methode mentioed above?
how to use the below u havce mentioned
ip accounting
-Netflow
thanks
Don't check for it.
write an ACL matching that ip address and police it according your needs. under the class definition you will match that ACL rather than some marks or signals.
Alessio
