Bandwidth Guarantee SubInterfaces
Fabien GRAGLIA
Community Member
i cheked differents solutions but that's not works. I'm searching to configure Bandwidth Guarantee on my fastethernet 0/1.2
class-map match-all TrfBWG
match input-interface FastEthernet0/0
policy-map TrfBWG
class TrfBWG
    priority 512000
policy-map PARENT
class class-default
    shape average percent 50
  service-policy TrfBWG
Return this Message, when i enter service policy PARENT output  command.
Insufficient bandwidth 1024 kbps for the bandwidth guarantee
ip nat outside
ip virtual-reassembly
rate-limit input 1024000 192000 384000 conform-action transmit exceed-action drop
rate-limit output 1024000 192000 384000 conform-action transmit exceed-action drop
duplex auto
speed auto
Who can help ?
(sorry for my english, i'm french)
I hope that's ok !
Hitesh Vinzoda
Level 10
Level 10
i think you cant use priority xxxx and percent in shaping together
try configuring priority percent instead of priority 512000
also by default you can only use 75% of the interface bandwidth so better you apply qos as below
priority xxxx
shape average XXXX (Rate to shape)
Hitesh
Pls rate useful posts
Hitesh Vinzoda
Level 10
Level 10
priority xxxx
Hitesh
Ok, thanks, maybe can you help me ? i search a solution to implement bandwidth guarantee on my Subinterfaces 0/1.2.
How can i do it ?
i think i have a problem with queue limit :
Service-policy output: PARENT
    Class-map: class-default (match-any)
      5064 packets, 4956870 bytes
      5 minute offered rate 66000 bps, drop rate 0 bps
      Match: any
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 5064/4957294
      shape (average) cir 1000000, bc 4000, be 4000
      target shape rate 1000000
      Service-policy : TrfBWG
        Class-map: TrfBWG (match-all)
          5055 packets, 4956294 bytes
          Match: input-interface FastEthernet0/0
          Queueing
          (pkts output/bytes output) 5055/4956718
          bandwidth 25% (250 kbps)
          9 packets, 576 bytes
          5 minute offered rate 0 bps, drop rate 0 bps
          Match: any
          (pkts output/bytes output) 9/576
Also you have policing configured on FA0/0 which seems to be your outgoing interface to internet.
You will need to explain what you need to achieve and explain the whole scenario ... that would help to compile the commands for your configuration.
Hitesh
So; i want to give bandwidth guarantee (512 k) on my subinterface FE 00/1.2, where bandwidth on my FE 0/0 (Internet access) been 2M.
it's possible ?
thanks again, sorry for my bad communication.
actual config :
policy-map TrfBWG
class TrfBWG
    bandwidth percent 25
policy-map PARENT
class TrfBWG
    shape average 1000000
