Bandwidth limit on VLANS using Cisco 3750 Layer 3 Switch
cuartoarcangel
Hi I have been trying to police bandwidth per VLAN on a 3750 Switch (ver 12.2 (44) SE5)
This is what i have:
- 40 Mbps Internet Service
- 10 VLANS
- I need each vlan to have assigned 4Mbps download and 1Mbps upload (that is, each workstation connected to a particular Vlan to download at 4Mbps and 1 Mbps upload).
So far i've only been able to control the upload using the following config (for testing purposes I'm limiting  only Vlan 7 as of now):
Gi 1/0/2 is connected to a Layer 2 Switch (2950) and every user woking in Vlan 7 in that switch (the 2950) is restricted to 1Mbps UPLOAD.
HOW can I restrict DOWNLOAD?, as of now if try to use the command:
LAYER_3(config-if)#service-policy output VLANs
It replies that the command is NOT supported.
LAYER_3#sh run
Building configuration...
Current configuration : 8989 bytes
! Last configuration change at 07:56:23 UTC Mon Mar 8 1993
version 12.2
service config
hostname LAYER_3
boot-start-marker
boot-end-marker
ip routing
mls qos
vlan internal allocation policy ascending
class-map match-all VLAN7
  match access-group 7
class-map match-all PORTS
  match input-interface  GigabitEthernet1/0/2
policy-map PORT
class PORTS
  police 1024000 192000 exceed-action drop
policy-map VLANS
class VLAN7
   set dscp ef
   service-policy PORT
interface GigabitEthernet1/0/1
switchport access vlan 192
switchport mode trunk
description LINK_SW_2_Floor
mls qos vlan-based
interface GigabitEthernet1/0/3
description INTERNET_LINK
no switchport
ip address 172.31.1.2 255.255.255.248
interface GigabitEthernet1/0/4
switchport access vlan 4
interface GigabitEthernet1/0/5
switchport access vlan 5
interface GigabitEthernet1/0/6
switchport access vlan 6
interface Vlan1
no ip address
shutdown
interface Vlan2
ip address 172.31.2.1 255.255.255.0
interface Vlan3
ip address 172.31.3.1 255.255.255.0
interface Vlan4
ip address 172.31.4.1 255.255.255.0
interface Vlan5
ip address 172.31.5.1 255.255.255.0
interface Vlan6
ip address 172.31.6.1 255.255.255.0
interface Vlan7
ip address 172.31.7.1 255.255.255.0
service-policy input VLANS
interface Vlan8
ip address 172.31.8.1 255.255.255.0
interface Vlan9
ip address 172.31.9.1 255.255.255.0
interface Vlan10
ip address 172.31.10.1 255.255.255.0
interface Vlan11
ip address 172.31.11.1 255.255.255.0
ip default-gateway 172.31.1.1
ip route 0.0.0.0 0.0.0.0 172.31.1.1
logging esm config
access-list 7 permit 172.31.7.0 0.0.0.255
Thanks in advance for your time reading this
16 Replies 16
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Bilal Nawaz wrote:
Hello, Shaping is not available on the 3750 I think.
BTW, "shaping" is availalbe on the egress port and also available, per QoS enabled egress queue.
Joseph W. Doherty
Disclaimer
Posting
On the 3750, you could apply a ingress policy and look for non-internal destination IPs.  For those, you could police that traffic.  That would limit your outbound, to the Internet, to some bandwidth per VLAN.
Conversely, if you apply an ingress policy on the port connected toward the Internet, you can policy can match against each VLAN block address and police the rate to it.  This would limit the maximum bandwidth consumption, from the Internet, per VLAN.
Note policing Internet after its already come down you Internet connection doesn't fully guarantee actual bandwidth consumption won't be higher than the policed value.  This because your policer is "downstream" of the link.
You can do similar on a router, but on a router, you would also be able to shape your VLAN traffic to the Internet.  This is a little less "brutal" and the 1 Mbps outbound would work a bit better.
If you outbound bandwidth is less than the physical interface bandwidth, you can "shape" for the aggregate outbound bandwidth limit.
