bandwidth remaining QoS config
Sam Oesterling
I just wanted to confirm my understanding on a sample QoS configuration I created here.
policy-map child
class video
  priority percent 10
class voip
  priority percent 15
class replication
  bandwidth remaining percent 50
class gold
  bandwidth remaining percent 15
class vpn
  bandwidth remaining percent 30
class class-default
  random-detect
policy-map parent
class class-default
  shape average 10000000
  service-policy child
This policy will be applied to a GigE interface that is connected to a metro ethernet connection with an SLA of 10Mbps.  I want to make sure that when the priority traffic is not in using all of it's bandwidth (low amount of phone calls or no video conference going on) that other data classes are given the resources it needs.  This is important because we are replication Data Domain traffic over this metro link as well.  We are starting to have some backlogging issues.  I want to allow Data Domain replication to comsume as much bandwidth as needed during normal business hours, however, when VPN traffic, and other important data traffic need resources, I want my QoS policy to allow it.  Right now we shape replication to 7Mbps to allow room for other traffic, but I am considering removing shaping.
Will this policy do the trick?  I am pretty sure this will work, but I wanted to double check before I promote something like this to my production network.
Thanks in advance.
Ugh...now you want me to do math ... fair warning
Okay...the priority percent is going to be based off of your 10Mb link. The bandwidth remaining is based off of what wasn't already allocated to other classes.
If your priority classes were completely maxed out:
priority percent 10 - Guaranteed and policed at 1Mb
priority percent 15 - Guaranteed and policed at 1.5Mb
                                                               Total 2.5Mb
That leaves 7.5Mb
So I get 2.25Mb for VPN....it looks like the math is right...
HTH, John *** Please rate all useful posts ***
10 Replies 10
Sam Oesterling
Oh, and I want higher rates when priority traffic is not in use, hense why I used "bandwidth remaining percent".
Personally, I don't see anything wrong with the config. The bandwidth percent/remaining percent guarantees you'll get that much during congestion, but it will allow full bandwidth utilization when nothing else is in the queue. Bandwidth remaining isn't used very often though.
So lets say there is no priority traffic on the link, and replication is taking all of the 10Mbps.  A VPN client connects and starts to download a large file from the network.  The VPN client should get 3000Kbps in that case, correct?  Since o priority traffic is on the link and VPN is allowed 30% of what remains (which is all 10Mbps).
Worst case if all priorty classes are maxed out (video and voice),  VPN would get 2250Kbps (as indicated on "show policy-map int int" command), correct?
I just want to make sure I get the most of out of this circuit and make sure my understanding on bandwidth remaining is accurate.
                                                               Total 2.5Mb
That leaves 7.5Mb
Thanks!
Thanks for the rating!
davy.timmermans
Level 4
Level 4
As J. says- bandwidth remaining is not that often used.
You could say
class video
  priority percent 10
class voip
  priority percent 15
class replication
  bandwidth percent 37    !  = bandwidth remaining 50%  (= (100 - 10 - 15)/2) !100 should be 75 by default -see *
class gold
  bandwidth percent x  (x =15% (100-10-15-37) )
class next
bandwidth percent y
you see how difficult it is? Each next class guaranteed bandwidth depends of the previous remaining bandwidths. I think it's better to configure it in the opposite way. By asking yourself - how much bandwidth do I want to guarantee minimum (maximum for LLQ - priority queues - starvation)
By default, when the bandwidth percent and priority percent commands are used to allocate bandwidth, the sum of the bandwidth percentage allocated to the high priority traffic and the bandwidth percentage allocated to the non-priority traffic cannot exceed 75 percent of the total bandwidth available on the interface.
The remaining 25 percent of the total bandwidth available on the interface is kept in reserve for the unclassified traffic and routing traffic, if any, and proportionally divided among the defined traffic classes. To override the 75 percent limitation, use the max-reserved bandwidth command in interface configuration mode.
When using bandwidth remaining - the remaining bandwith is calculated based on the max-remaining bandwidth of the interface
class video
  priority percent 10
class voip
  priority percent 10
class test
bandwith remaining percent x
Eg. 10 Mbps interface
Results for class test
x percent of remaining bandwidth (7,5 Mbps (default) - 1 Mpbs (=10% voice of 100% bw) - 1 Mbps(=10% video of 100% bw)) =
x% of 5,5 Mbps
Joseph W. Doherty
Disclaimer
The    Author of this posting offers the information contained within this    posting without consideration and with the reader's understanding that    there's no implied or expressed suitability or fitness for any  purpose.   Information provided is for informational purposes only and  should not   be construed as rendering professional advice of any kind.  Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
Some IOS versions, if I remember correctly, will show the actual calculated bandwidth per class.  You might try a show policy interface and see if your version does.
Different IOS versions also have different rules in bandwidth calculations.  There's a major difference between pre-HQF and HQF policies, and some IOS/platforms are different still (e.g. the EOL 7500s, FlexWAN cards, SIP-200/400).
"Remaining bandwidth" has nothing to do with actual available bandwidth when there's congestion between queues, it's just a different method to specify how bandwidth is to be proportioned to a class.
I recall (?) earlier versions of CBWFQ didn't support any percentages.  This made it inconvenient to use the same policy on interfaces of different bandwidths unless you understood exactly how bandwidth, on classes work.
If I had a fractional T1 of 1 Mbps, you might want a policy like:
policy-map example
class low-volume
bandwidth 200
class high-volume
bandwidth 800
This would fail on earlier CBWFQ versions because there's always a default-class, and in earlier versions, it "reserves" 25% of the bandwidth.  For those versions, if you reset the interface default to allow 100% allocation, the prior policy would work with 1 Mbps, but wouldn't work on 500 Kbps fractional T1.
The above policy allows either class to use all available bandwidth.  Only when all classes want full bandwidth, do you obtain the defined "reservations".  For example, in the above policy, if high-volume traffic only offered 300 Kbps, low-volume could use 700 Kbps.
What's important to realize, CBWFQ actually assigns relative weights to classes, so the following, example2, really is much the same.
policy-map example2
class low-volume
bandwidth 20
class high-volume
bandwidth 80
This policy, though, could be assigned to the 500 Kbps fractional T1.  It could also be assigned to the 1 Mbps fractional T1 without needing to change the default reserve allocation.  It would also work about the same, without changing the default reserve allocation, if there was no traffic in class-default.  (NB: again, there's always a class-default, i.e. it can be implicit.)
Also again, it's really better to understand bandwidth proportion between the two classes are 1:4, in either example, although we're use to thinking in "bandwidth reservations", but that's not how the CBWFQ scheduler really works.
To make things "clearer", CBWFQ policies can use percentages.
policy-map exampleA
class low-volume
bandwidth percent 20
class high-volume
bandwidth percent 80
and
policy-map example2A
class low-volume
bandwidth percent 2
class high-volume
bandwidth percent 8
Would work much as described, although now you need not worry about exceeding the bandwidth assigned to the interface.  Remember bandwidths of 200/800 couldn't be used on a 500 Kbps fractional T1, but either of the percent usage policies could.
In later IOS versions, remaining percentage was allowed, so you could have a policy like:
policy-map example3
class low-volume
class high-volume
bandwidth remaining percent 100
This policy also create 1:4 proportion.  However example3 is not the same as:
policy-map example3a
class low-volume
bandwidth percent 2
class high-volume
or
policy-map example3b
class low-volume
class high-volume
bandwidth remaining percent 80
So far, I've only discussed defined classes, but as your child policy has a class-default, you should know some (pre-HQF, non-7500 like) CBWFQ only supports fair-queue in class-default.  When used there, each FQ flow is independently scheduled, which effectively distorts all you other class bandwidth allocations.  I recall for these CBWFQ version, FQ is also the default for class-default.
I could go on, but suspecting you just want a policy that works, you might try:
policy-map childA
class LLQ
  priority percent 30
class class-default
  fair-queue
or
policy-map childB
class LLQ
  priority percent 30
class replication
class class-default
  fair-queue
Which depends on how many flows replication might generate.  If very few, use childA, if not very few, use childB.
Also, not all shapers account for L2 overhead, if your doesn't you might need to set the shape rate down by about 5 to 15%.  Additionally, for VoIP you might need to decrease the shaper's default Tc (if 25 ms).
PS:
If your IOS supports HQF (and if not, consider upgrading to one that does), you have a policy like:
policy-map childHQF
class LLQ
  priority percent 30
class replication
  fair-queue
class gold
  bandwidth remaining percent 49
  fair-queue
class vpn
  bandwidth remaining percent 25
  fair-queue
class class-default
  fair-queue
Adjust percentages as needed.
Wow Joseph, thanks for all of that.
Yes, when running show policy-map, it does show the minumum bandwidth and it allocates it as I expected.
Here is my question.  That there seems to be a lot of confusion on.
If my priority queues are not using the minimum guaranteed bandwidth, will that "excess" be distrubuited to all of the "bandwidth remaining" classes.
I am running IOS 15.1(4)M1 on a 3845 ISR, so it does support HQF.
Disclaimer
Posting
Any actual bandwidth that's not being used for actual traffic is available to other classes.  Whether other class traffic can use that bandwidth depends whether that class is being policed or shaped.  (BTW, LLQ classes can exceed their limit if there's actual excess bandwidth.)
NB: "remaining" doesn't have anything to do with actual excess bandwidth usage, only how weight for a class is calculated. "Remaining" allocates/calculates from the aggregate of non-remaining.  So for example if 40% has been allocated non-remaining, 100% remaining would be 60%; or if 70% has been allocated non-remaining, 100% remaining would be 30%.  The advantage of this approach is you don't have to reallocate all percentages with some class bandwidth percentage changes.
It should.
