Bandwidth Test Setup
trantuan
Visitor
Has anyone setup something similar to attachment?  If so, can you share the configuration?
What I am trying to do is to run some bandwidth test tool, like NTttcp, JPerf, iPerf, etc. on the PCs (PC-1 and PC-2).  But I wanted to test the actual ISP connections between Site-A and Site-B without installing the PC at Site-B.  Both PCs will be installed at Site-A.
I can use the same setup to test between Site-A and any site out there that I have configuration control over the remote router.  Of course, I don't have any configuration control over the ISP equipment but they are routing the networks I tell them via BGP.
I have look at GRE and VRF, but can't seem to make them work.
Thanks.
Philip D'Ath
Meraki Community All-Star
Can you not plug a PC into site 'b'?  Even a spare port on the router and use NAT?
I think this could skew your results quite a bit because of the CPU load.  Try creating two GRE tunnels between router  A and B.  Make sure you specify a tunnel key so the routers can tell them apart.
Router B is the easy one.  Something like:
Tunnel0
  ip address 192.168.0.10 255.255.255.252
  tunnel source ...
  tunnel destination ...
  tunnel key 0
Tunnel1
  ip address 192.168.0.14 255.255.255.252
  tunnel source ...
  tunnel key 1
ip route 192.168.0.0 255.255.255.252 192.168.0.9
ip route 192.168.4.0 255.255.255.252 192.168.0.13
Router A needs a bit more work.  Lets pretend the PC's are on gig0/0 and gig0/1.  Create two VRF's.
ip vrf A
ip vrf B
interface Gigabit0/0
  ip vrf forwarding A
  ip address 192.168.0.1 255.255.255.252
interface Gigabit0/1
  ip vrf forwarding B
  ip address 192.168.0.5 255.255.255.252
Tunnel0
  ip vrf forwarding A
  ip address 192.168.0.9 255.255.255.252
  tunnel source ...
  tunnel key 0
Tunnel1
  ip vrf forwarding B
  ip address 192.168.0.13 255.255.255.252
  tunnel source ...
  tunnel key 1
ip route vrf A 192.168.0.4 255.255.255.252 192.168.0.10
ip route vrf B 192.168.0.0 255.255.255.252 192.168.0.14
Give PC A the IP address 192.168.0.2/255.255.255.252 (GW=192.168.0.1) and PC B 192.168.0.6/255.255.255.252 (GW=192.168.0.5).
If you have it right, PC A and PC B should now be able to ping each other, going via the remote site.
