Bandwidth Throttling on a WAN Circuit
namso2
We are replicating data in one direction from Site A to Stie B. The source is a set of servers on Site A's LAN. The servers belong to three subnets. Only those servers reside in those subnets.
Site A has two core 6509 switches. These two switches each connect to a CE router. Each CE router connects to a PE router. The PE routers connect to two MPLS clouds at 130 Mbps.
It is similar at Site B.
What I want to do is limit the servers' traffic to 25 Mbps from Site A to Site B. Where is it best to rate-limit the traffic (6509 switch, CE router, or PE router)?
How would I go about doing that? I'm not asking for specific commands right now, but just an overview (e.g. use WRED). In other words, which software feature should I use?
tdrais
Level 7
Level 7
If you want a hard limit then you want to police the traffic. You want to limit the traffic as close to the source as you can. In your case I suspect it will be in the CE router. If all the traffic passes though a single core switch then you could do it at the switch. If it load balances into both interfaces in the CE router then your only common point is outbound on the CE router. It is not normally good to police the traffic outbound but it may not be easy to do another way. If you have good load balancing you could do 12.5m inbound on each connection from the core.
tdrais
Level 7
Level 7
tthulin
There are a couple of ways to do this, but the simplest would be to apply CBWFQ to the outbound interfaces. This will allow you to limit your server to a giving bandwidth and also to guarantee more "production data" a bandwidth. Some of these commands may be IOS dependent, but it will give you a idea of where to start.
The example here is for Frame-relay
For example I will use 10.1.1.0 /23 for site A lan
and 10.1.2.0/23 for site B's Lan.
1. So we start by create a source/destination access-list
On Site A side
access-list 101 permit ip 10.1.1.0 0.0.0.255 10.1.2.0 0.0.0.255
On Site B side
access-list 101 permit ip 10.1.2.0 0.0.0.255 10.1.1.0 0.0.0.255
2. Now create a class-map for this data
class-map match-all rep-data
match access-group 101
3. Now create a policy-map and associate it to teh class-map
policy-map FRF-QoS-Rep-Data
class rep-data
bandwidth 25600
class class-default
fair-queue
4. Create a map-class for your bandwidth
map-class frame-relay FRF-QoS-Rep-Data
frame-relay cir 130000000
frame-relay mincir 25000000
service-policy output FRF-QoS-Rep-Data
5. Apply Frame-relay traffic shaping to primary interface. (skip if not using FR)
Interface Serial1/0
Frame-relay traffic-shaping
6. Apply map-class to sub interface dlci if you are using FR
Interface Serial1/0.1 point-to-point
frame-relay interface-dlci 101
class FRF-QoS-Rep-Data
This will guarantee 25 meg for you rep server and fair-queue everything else. You can make as bandwidth groups as you wish, but the additive of all groups should be equal or less than your min cir.
