Bandwith Control or QoS on Cisco Router
c.ong
Hi Sir,
HQ is running Cisco 2621 and remote branch is running Cisco 805.
The current CCTV traffic always caused other application like SAP fail to connect to HQ from remote branch. They want to limit CCTV traffic to 1 Mbps only, another 1 Mbps purely for SAP & others.
How can we provide bandwidth traffic shaping or control to achieve the above on the router 805? Customer has one spare Cisco 2811 to replace the Cisco805 if limited QoS functionality is supported on the remote branch router.
Hope to hear from your advise.
-delon
Akash Agrawal
If your router supports CBWFQ, try below steps
- Define class to match CCTV traffic
- Create a policy-map, call CCTV class and assign bandwidth 1 mbps
- Under class class-default assign bandwidth 1 mbps
Class-map match-any CCTV
 match CCTV traffic
policy-map Policy-Out
class CCTV
bandwidth 1000
class class-default
bandwidth 1000
I believe your link is 2mbps link.
Akash
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Cannot say for sure for the 805, but the later 800 series models, with the right IOS, seem to support most if not all that version's IOS commands on the "WAN" port.
For your other ISRs, like your 2621 and 2811, IOS feature support depends on IOS version.
Given support for CBWFQ IOS, you should be able to shape or police, although from what you describe, I would just recommend prioritization of SAP traffic or deprioritization of CCTV traffic (or a combination).
"Combination" example:
policy-map example
class SAP
priority percent 50
class CCTV
bandwidth remaining percent 1
class class-default
bandwidth remaining percent 99
fair-queue
