Basic BGP Configuration
jonhill
Level 3
Level 3
I'm very new to BGP and have been using GNS3 to help me understand how to configure BGP on Cisco IOS. See below what my test network looks like and I've attached the configs from the 3 devices.
I'm seeing the 3 VLAN's on the LAN Core in the Gateway and CPE01 routing tables. I can ping the 3 VLAN interfaces from the Gateway device but not on the CPE01, when I do a trace route from the CPE01 device to the VLAN interfaces first hop is Gateway VLAN 600 address and then it fails.
Any help would be much appreciated?
The configs are correct. Which devices are you using in GNS3 ?
8 Replies 8
Georg Pauwen
I don't see the configs (sh run) attached...
LAN Core
interface Loopback0
no ip address
interface Ethernet0/0
no switchport
ip address 10.170.94.2 255.255.255.252
duplex auto
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
--More--  !
interface Ethernet1/0
interface Ethernet1/1
interface Ethernet1/2
interface Ethernet1/3
interface Ethernet2/0
interface Ethernet2/1
interface Ethernet2/2
interface Ethernet2/3
interface Ethernet3/0
interface Ethernet3/1
switchport access vlan 103
interface Ethernet3/2
--More--   switchport access vlan 102
interface Ethernet3/3
switchport access vlan 101
interface Vlan1
no ip address
shutdown
interface Vlan101
ip address 10.170.0.1 255.255.252.0
interface Vlan102
ip address 10.170.4.1 255.255.252.0
interface Vlan103
ip address 10.170.8.1 255.255.252.0
router bgp 100
bgp log-neighbor-changes
network 10.170.0.0 mask 255.255.252.0
network 10.170.4.0 mask 255.255.252.0
network 10.170.8.0 mask 255.255.252.0
--More--   neighbor 10.170.94.1 remote-as 100
ip forward-protocol nd
no ip http server
no ip http secure-server
Gateway
no switchport
ip address 10.170.94.1 255.255.255.252
duplex auto
switchport access vlan 600
--More--  interface Ethernet1/0
--More--  !
interface Vlan1
no ip address
shutdown
interface Vlan600
ip address 10.170.39.1 255.255.255.240
router bgp 100
neighbor 10.170.39.9 remote-as 65057
neighbor 10.170.94.2 remote-as 100
no ip http server
CPE01
no switchport
ip address 10.170.39.9 255.255.255.240
duplex auto
--More--  interface Ethernet1/1
interface Vlan1
--More--   no ip address
shutdown
router bgp 65057
neighbor 10.170.39.1 remote-as 100
no ip http server
your LAN Core router does not have a route back to CPE01. You can add a static route on the LAN Core router:
ip route 0.0.0.0 0.0.0.0 10.170.94.1
Also, configure the neighbors in AS100 with next hop self:
LAN Core
neighbor 10.170.94.1 next-hop-self
Gateway
neighbor 10.170.94.2 next-hop-self
Thanks for the info, I added what you recommended below but I still can't ping from CPE01 to any address on LAN Core
post your running configs again with the changes...you might have misconfigured something...
See below config with changes.
CPE
no switchport
duplex auto
interface Vlan1
no ip address
shutdown
router bgp 65057
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
Gateway
no switchport
duplex auto
interface Vlan1
no ip address
shutdown
interface Vlan600
router bgp 100
no ip http server
LAN Core
interface Loopback0
no ip address
no switchport
duplex auto
interface Vlan1
no ip address
shutdown
interface Vlan101
interface Vlan102
interface Vlan103
router bgp 100
no ip http server
I'm using switches running Cisco IOU L2 15.2d
