basic Cisco 887VA Config
adrianleary
HI i am currently banging my head against a desk trying to figure out what i am missing here, I am trying to configure A Cisco 887VA router to connect to the internet:
I can get the router to ping www.google.com
I can ping the internal LAN (192.168.0.2)
I can see the router from the LAN
I can see the router from the internet
So my problems are:
1/ I can’t get the router to pass information from the LAN to the WAN (I can’t see the internet from the LAN)
2/ I can’t get the username & password to work for the “IP http server”
What am i doing wrong here? Any help would be greatly appreciated…
The Router version Info is:
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.2(4)M4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 20-Jun-13 16:47 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
Telstra-ADSL_Router uptime is 2 hours, 26 minutes
System returned to ROM by reload at 00:15:44 UTC Fri Nov 29 2013
System image file is "flash:c880data-universalk9-mz.152-4.M4.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 887VA (MPC8300) processor (revision 1.0) with 236544K/25600K bytes of memory.
Processor board ID FGL17382417
1 DSL controller
1 Ethernet interface
4 FastEthernet interfaces
1 ATM interface
1 Virtual Private Network (VPN) Module
256K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO887VA-SEC-K9     FGL17382417
License Information for 'c880-data'
    License Level: advipservices   Type: Permanent
    Next reboot license Level: advipservices
Configuration register is 0x2142
The current Configuration is:
Telstra-ADSL_Router#show config
Using 2705 out of 262136 bytes
! Last configuration change at 02:08:19 UTC Fri Nov 29 2013 by admin
version 15.2
no service pad
hostname Telstra-ADSL_Router
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
crypto pki trustpoint TP-self-signed-3115301035
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3115301035
revocation-check none
rsakeypair TP-self-signed-3115301035
crypto pki certificate chain TP-self-signed-3115301035
certificate self-signed 01 nvram:IOS-Self-Sig#5.cer
no ip source-route
ip dhcp excluded-address 192.168.0.0 192.168.0.10
ip dhcp pool lan
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
dns-server 139.130.4.4 203.50.2.71
lease infinite
no ip bootp server
ip domain name leary.net.au
ip name-server 139.130.4.4
ip name-server 203.50.2.71
ip cef
no ipv6 cef
license udi pid CISCO887VA-SEC-K9 sn FGL17382417
archive
log config
  hidekeys
username (username) password 0 (password)
controller VDSL 0
ip ssh time-out 90
ip ssh authentication-retries 2
interface Ethernet0
no ip address
shutdown
interface ATM0
description --- Internode ADSL ---
no ip address
no atm ilmi-keepalive
pvc 8/35
  tx-ring-limit 3
  encapsulation aal5snap
  pppoe-client dial-pool-number 1
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
description --- Ethernet LAN ---
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip nat enable
ip virtual-reassembly in
ip tcp adjust-mss 1420
interface Dialer0
ip address (Public IP Address) (Subnet)
ip mtu 1460
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname (ISP Username)
ppp chap password 0 (ISP password)
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
no ip nat service sip udp port 5060
ip nat inside source list NAT interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip access-list extended MGMT-IN
permit ip (Public IP Address) (Subnet) any
permit ip 192.168.0.0 0.0.0.255 any
ip access-list extended NAT
no cdp run
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class MGMT-IN in
login local
transport input all
scheduler max-task-time 5000
sntp server 192.168.0.9
end
0 Replies 0
