Redistributing RIP & BGP but unable to get routes
Neeraj Patial
Hi All,
Please help i have 9 routers in my project R1,R2,R3,R4,R5,R6,R7,R8,R9 WHERE R1,R7,R8,R9 are CE routers & rest are PE routers.
i want to redistribute RIP into BGP & below are config.of  CE(R1) & PE(R2) as i run show ip route in R1 then unable to find BGP routes please confirm What is issue in config
Now i have configured RIP in R1 & config are
interface Loopback0
ip address 203.1.0.1 255.255.255.255
interface Loopback1
ip address 203.1.1.1 255.255.255.0
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet2/0
ip address 150.1.0.0 255.255.255.254
duplex auto
speed auto
router rip
version 2
network 150.1.0.0
network 203.1.0.0
network 203.1.1.0
R2 config
interface Loopback0
ip address 192.168.1.1 255.255.255.255
interface Ethernet0/0
no ip address
shutdown
duplex auto
interface GigabitEthernet0/0
ip address 192.168.1.6 255.255.255.254
media-type gbic
speed 1000
duplex full
negotiation auto
vrf forwarding vpnb
ip address 150.1.0.3 255.255.255.254
duplex half
vrf forwarding vpna
ip address 150.1.0.1 255.255.255.254
duplex full
interface FastEthernet3/0
no ip address
shutdown
duplex half
router ospf 1
log-adjacency-changes
network 192.0.0.0 0.255.255.255 area 0
mpls ldp sync
mpls ldp autoconfig
router rip
version 2
address-family ipv4 vrf vpna
  redistribute bgp 1 metric transparent
  network 150.1.0.0
  no auto-summary
exit-address-family
router bgp 1
no bgp default ipv4-unicast
bgp log-neighbor-changes
neighbor 192.168.1.5 remote-as 1
neighbor 192.168.1.5 update-source Loopback0
address-family ipv4
  no synchronization
  neighbor 192.168.1.5 activate
  no auto-summary
exit-address-family
address-family vpnv4
  neighbor 192.168.1.5 send-community extended
exit-address-family
  no synchronization
  redistribute rip
exit-address-family
address-family ipv4 vrf vpnb
  no synchronization
  redistribute connected
  redistribute static
exit-address-family
no ip http server
no ip http secure-server
ip route vrf vpnb 203.1.0.2 255.255.255.255 150.1.0.2
ip route vrf vpnb 203.1.2.0 255.255.255.0 150.1.0.2
mpls ldp router-id Loopback0
--More--
lmediavilla
First do a no auto summary on your CE router in router rip
ip address 150.1.0.0 255.255.255.254, this mask /31 must be used with caution, it may cause problems, It's not recommended to use anything smaller than a /30
The PE config looks ok, but to see rip routes or bgp routes or other pe or ce routers you need to have them imported probably the vrf router-target export and import and the rd
you must import what others PE exports and export what the others import in order to exchange routes
kind regards
5 Replies 5
lmediavilla
kind regards
Reuben Farrelly
Level 3
Level 3
Are you really really really sure you need to redistribute RIP into BGP?  It'll add a much greater level of complexity into not only your configuration job, but also the operation of the devices and support of them going forward.
Having two separate protocols running on the router is OK, but specifically -not- redistributing will make your troubleshooting much easier.  I would only recommend you redistribute those two protocols into each  other if there was no other way (such as using static routes) to solve  the problem.
Probably he is just testing or doing a lab but there is nothing wrong configuring MP-BGP you will have direct communication between sites, hub and spoke is easyer (NHRP) but you will loose the direct end to end communication without going to the central site.
Julio Carvajal
Please post the VRF configuration to check the RD and RT (make sure the import and export match on both sides as properly).
On the BGP protocol do you see any routes being learned?
Rate all of the helpful posts!!!
Jcarvaja
Follow me on http://laguiadelnetworking.com
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Hi Imediavilla,
Thanks a lot now i am able to ping my loopback to loopback IPs which was initially not happen as i have configure no auto summary in RIP of my CE its working & on PE R2 im getting all BGP routes.
Aside All Thanks for your suggestions
Neeraj
