Showing results forĀ
Search instead forĀ
Did you mean:Ā
Basic Config not working
nuno
Hi Guys - Could you tell  me what im doing wrong here
Im new to all of this and i have setup this ADSL router for testing. I can ping etc from the router to the outside world but nothing from the lan - no internet nothing.
no service pad
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname jhb-rs
boot-start-marker
boot-end-marker
memory-size iomem 5
logging buffered informational
enable secret 5 $1$MvU7$LKV9sJRJ7scONMWGLwPaV1
no aaa new-model
resource policy
ip subnet-zero
no ip dhcp use vrf connected
ip dhcp pool office
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   dns-server 196.35.64.215 196.31.134.202
   lease infinite
ip cef
no ip bootp server
no ip ips deny-action ips-interface
no ftp-server write-enable
no crypto isakmp ccm
interface Ethernet0
description $FW_INSIDE$
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
no keepalive
no cdp enable
hold-queue 100 in
hold-queue 100 out
interface Ethernet2
no ip address
shutdown
hold-queue 100 out
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no atm ilmi-keepalive
dsl operating-mode auto
dsl power-cutback 30
interface ATM0.3 point-to-point
description Layer2 Connectivity
no ip redirects
no ip unreachables
no ip proxy-arp
pvc 8/35
  pppoe-client dial-pool-number 3
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet2
no ip address
duplex auto
speed auto
interface FastEthernet3
no ip address
duplex auto
speed auto
interface FastEthernet4
no ip address
duplex auto
speed auto
interface Dialer3
description $FW_OUTSIDE$
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1432
dialer pool 3
dialer-group 1
no keepalive
no cdp enable
ppp authentication pap callin
ppp pap sent-username blah@isdsl.de password 7 10180A4F510005121F
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer3
no ip http server
no ip http secure-server
access-list 1 permit 192.168.1.0 0.0.0.255
snmp-server enable traps tty
no cdp run
control-plane
line con 0
exec-timeout 2 0
no modem enable
stopbits 1
line aux 0
line vty 0 4
exec-timeout 2 0
login
scheduler max-task-time 5000
end
cadet alain
you assigned the NAT to interfaces but you are not doing any NAT.
You need to add tthis:
ip nat  inside source list 1 interface dialer3 overload
Regards.
Alain.
