Basic Routing problem
maheshsankpal
Hi..
I have cisco 2911 series router.I am trying to do a simple router set up.
My ISP provide me following IP addresses with single physical connection.
Primary WAN IP: 58.xx.xxx.6 255.255.255.252  Gateway: 58.xx.xxx.5
                                        and
Secondary WAN IP: 58.xx.xx.2 255.255.255.248 Gateway: 58.xx.xx.1
                              58.xx.xx.3 255.255.255.248 Gateway: 58.xx.xx.1
                              58.xx.xx.4 255.255.255.248 Gateway: 58.xx.xx.1
LAN IP addresses: 27.xxx.xxx.66 255.255.255.248 Gateway: 27.xxx.xxx.65
                            27.xxx.xxx.67 255.255.255.248 Gateway: 27.xxx.xxx.65
                            27.xxx.xxx.68 255.255.255.248 Gateway: 27.xxx.xxx.65
                            27.xxx.xxx.69 255.255.255.248 Gateway: 27.xxx.xxx.65
                            27.xxx.xxx.70 255.255.255.248 Gateway: 27.xxx.xxx.65
I have configured
interface GigabitEthernet0/1
ip address 58.xx.xx.2 255.255.255.248 secondary
ip address 58.xx.xxx.6 255.255.255.252
interface GigabitEthernet0/0
ip address 27.xxx.xxx.65 255.255.255.248
IP route i configured is
ip route 0.0.0.0 0.0.0.0 58.xx.xxx.5
ip route 0.0.0.0 0.0.0.0 58.xx.xx.1
Now ip address 27.xxx.xxx.64/29 is working properly. but i am not able to use 58.xx.xx.3,58.xx.xx.4 the ISP provided IP addresses.
I can ping from the Router2911 to 58.xx.xx.1.
I cannot ping from the PC to 58.xx.xx.1
Simply, I want to use secondary WAN IP addresses (58.xx.xx.3,58.xx.xx.4) on my local PC.
The problem I am having is that it is not routing and I cannot see what I am missing.
Here is my current router configiration...
Building configuration...
Current configuration : 1420 bytes
! Last configuration change at 14:34:40 UTC Thu Sep 12 2013
version 15.2
service password-encryption
hostname Cisco_Router
boot-start-marker
boot-end-marker
enable secret 4 tS/M3box6xxvJmxx7SPxxyQHEgxxMtxxxPfeTxnxx0E
no aaa new-model
ip cef
ip name-server 202.xxx.xxx.x
no ipv6 cef
license udi pid CISCO2911/K9 sn FGLxxx11xxG
username cisco privilege 15 password 7 15xxx21Fxx25xx7Dxx62
interface Embedded-Service-Engine0/0
no ip address
shutdown
duplex auto
speed auto
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password 7 070xxx5Fxx06xx5Cxx43
login
transport input all
scheduler allocate 20000 1000
end
milan.kulik
Level 10
Level 10
IMHO, it has no sense to configure
ip address 58.xx.xxx.5 255.255.255.252
and
at the same time.
According to your ISP provided info
you shoud configure
on your router.
Also I don't uderstand the purpose of secondary WAN IP towards your ISP?
Best regards,
Milan
There are a couple of things going wrong in your setup in addition to the misconfiguration pointed out by Milan.
First, use the /30 network as a pure transfer network to your ISP:
Then tell you provider to route the network 58.xx.xx.0 255.255.255.248 (where xx.xx is hopefully a different xx.xx then the one on gig0/1; it wouldn't make any sense otherwise) to your IP 58.xx.xx.6. Now you can use this network in your local LAN. For example with the following config:
Or you can use the two networks on different VLANs that you split on your switch:
interface GigabitEthernet0/0.10
  encapsulation dot1Q 10
interface GigabitEthernet0/0.20
  encapsulation dot1Q 20
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Hi Karsten,
  As per your suggestions, i have configured my router. now i am waiting for my ISP reply.
Thank you very much. i will get back on this later.
