Basic Routing question
ittechk4u1
Level 4
Level 4
Hello experts,
I got IP address from ISP to configure point to point connection .
But we requested to use 8 public ip address so ISP gave one point to point IP and rest 8 with complete diff IP range:
PUBLIC1: ISP for point 2 point: 197.36.128.214/30 , 197.36.128.213 is used on ISP device
PUBLIC2: for more 8 public IP address: 197.36.128.160/29
and ISP told that he routed PUBLIC2 network over PUBLIC 1
so How I should configure my router to get access to internet ...
Thanks in advance.
21 Replies 21
Georg Pauwen
the below should do it:
interface FastEthernet0/0
ip nat inside
interface GigabitEthernet0/0
ip address 197.36.128.214 255.255.255.252
ip nat outside
ip nat pool NAT_POOL_1 197.36.128.161 197.36.128.166 prefix-length 29
ip nat inside source list 1 pool NAT_POOL_1
access-list 1 permit 192.168.1.0
I tried this but still not working!!!!
i confgured exactly as you said...
then configured a GRE tunnel with IP :197.36.128.165 but tunnel is not coming up
post the full configuration you have so far...
there is no isakmp in your output. Post the full running configuration (sh run) of both sides,  BRRCVPN4 and BRRCVPN3.
Hi, Let me start with scratch:
I got two ISP range from ISP:
Public 1: 196.36.220.212/30
196.36.220.213 - ISP Device
196.36.220.214  - Our VPN router
Public 2: 197.96.128.160/29
Here is the provider router config:
interface GigabitEthernet0/0/0/15.437
description l| VLAN437 | CEL12-11-0429
bandwidth 10240
service-policy input 1to3-10240K-INPUT
service-policy output 1to3-10240K-10240K-OUTPUT
vrf INTERNET
ipv4 address 196.36.220.213 255.255.255.252
ipv4 verify unicast source reachable-via rx
ipv4 unreachables disable
flow ipv4 monitor IPv4-MON-MAP sampler FNF_SAMPLER_MAP ingress
flow ipv4 monitor IPv4-MON-MAP sampler FNF_SAMPLER_MAP egress
encapsulation dot1q 437
   197.96.128.160/29 GigabitEthernet0/0/0/15.437 196.36.220.214
Questions:
1. Now i cant ping 196.36.220.213 from 196.36.220.214 , why ?
2. I need to access via SSH to 196.36.220.214 from ouside (internet), not possible why ?
once these two point works then i will create a GRE tunnel with router via PUBLIC 2 netwrok!!
do you have SSH access set up on your router ? Post the full running configuration of your router (sh run) not just snippets.
I cannot ping your router either, I can ping the ISP router. ICMP might be blocked on the provider end, so that doesn't necessarily mean anything.
see the attached conifg..
ghostinthenet
Level 7
Level 7
It depends on how you want things set up. Your WAN interface will hold the /30 subnet and will be your NAT outside interface. The /29 can be assigned to an interface if you actually want to assign the addresses to other devices directly, or if you're just using the network as a NAT pool, you can just reference the addresses in your NAT statements. (This will actually let you use all eight addresses in the /29 as there's no real network in play.) Traffic destined for the /29 will be routed by the ISP to your router's WAN interface and your router will take care of it from there.
How exactly do you want this /29 to be used? If you let me know, I can probably give more specific advice.
Jody Lemoine, Network Architect
CCIE 41436, MTCRE, MTCINE, MTCIPv6E
tishco networks, Virtually Everywhere
(905) 378-1134, jody.lemoine@tishco.ca
Thanks.
i want to have GRE IPsec tunnel from /29 IP address to our HQ.
Could you please provide me  a sample conifg, how should i can configure these.
Thanks again.
That's fairly easy to accomplish. Just attach the /29 to a loopback interface and source the tunnel off of that.
interface Loopback0
 ip address x.x.x.x 255.255.255.248
interface Tunnel0
 tunnel source Loopback0
what about the PUBLIC 1 IP address (.212/30) ?
That should already be attached to your WAN interface.
so you mean it should be like this:
int gig0/1
IP address PUBLIC1 (.214/30)
int loop1
ip add PUBLIC2 (.162/29)
and then we should create a  GRE tunnels with source address loop1 ?
No NATing required ?
could you please provide a sample config!!!!!
then what will be gateway  to prvode a default root ?
0.0.0.0 0.0.0.0 Gateway ?
