Best design for simple configuration
Rob
Hi everyone, let me apologize up front for my absolute lack of knowledge.  I'm new to routing and cisco in general.  I'm inheriting a rather simple setup but would like to approach the next steps with a good strategy.  Currently we have a 2901 router with public IP's on bother interfaces.  The internal facing interface is our gateway for some webservers and a firewall.  Not we are looking to add a colocation site and establish a site to site VPN using another 2901. My goal is to have the colocation use the same internal 10.100.0.0/23 network.  My question is what is the best way of going about this since the router at the main site has public IP's on both interfaces?  Do I need to multi-home the internal facing interface?  If so, what else needs to be done?
Thanks in advance.
Rob
andrew.prince
Level 10
Level 10
Rob,
First thing - it's never a good idea to have the same IP subnet at 2 seperate locations, you need to figure out traffic flows and your NAT.
Describe out the "other" site will connect and route?
