Best device to fit for a project
James Lasky
I'm not sure this is the right section but I try.
For a project (less than 100 branch offices and 2 Headquarters connected in an hub&spoke topology with IPSEC over MPLS among branch and HQ)
I’m looking for the best device which cover the following items:
Branch:
Single device
At least two Ethernet interfaces (WAN/LAN)
Ipsec supporting 10-50-100 Mbs 3DES
Routing protocols such as BGP-OSPF
NAT
Redundant power supply (some site not but in principle I need it)
HeadQuarter:
Single device with TenG intf
At least two XEthernet interfaces (WAN/LAN)
IPSEC supporting up to 7-10 Gbs of IPSEC 3DES (the sum of branches)
NAT
Firewall policy are not needed, MPLS will be runned by two carrier (this is why single device, there will be two single devices (with hsrp/vrrp) per site each one connected to one MPLS carrier), IPSECs tunnels are on-top of MPLS.
I’m looking for the best solution in terms of scalability and price (very important).
I've an idea in my mind but I'd like to share your experience for the decision...
d-fillmore
Level 2
Level 2
Your best bet might be to speak to a reseller, they should be able to give you some ideas
Thanks for the raccomendation, here there is the experience, reseller sells a lot of things...
Leo Laohoo
Duplicate posts.   cheeky
Go here:  http://supportforums.cisco.com/discussion/12161946/best-device-fit-project
